message_buffer.h
size_t xMessageBufferSendFromISR( MessageBufferHandle_t xMessageBuffer,
const void *pvTxData,
size_t xDataLengthBytes,
Interrupt safe version of the API function that sends a discrete message to
the message buffer. The message can be any length that fits within the
buffer's free space, and is copied into the buffer.
NOTE: Uniquely among FreeRTOS objects, the stream buffer implementation (so
also the message buffer implementation, as message buffers are built on top
of stream buffers) assumes there is only one task or interrupt that will write to
the buffer (the writer), and only one task or interrupt that will read from
the buffer (the reader). It is safe for the writer and reader to be
different tasks or interrupts, but, unlike other FreeRTOS objects, it is not
safe to have multiple different writers or multiple different readers. If
there are to be multiple different writers then the application writer must
place each call to a writing API function (such as xMessageBufferSend())
inside a critical section and use a send block time of 0. Likewise, if there are to be multiple different
readers then the application writer must place each call to a reading API
function (such as xMessageBufferRead()) inside a critical section and use a receive block time of 0.
Use xMessageBufferSend() to write to a message buffer from a task. Use
xMessageBufferSendFromISR() to write to a message buffer from an interrupt
service routine (ISR).
xMessageBuffer
The handle of the message buffer to which a message is
being sent.
pvTxData
A pointer to the message that is to be copied into the message
buffer.
xDataLengthBytes
The length of the message. That is, the number of
bytes to copy from pvTxData into the message buffer. When a message is
written to the message buffer an additional sizeof( size_t ) bytes are also
written to store the message's length. sizeof( size_t ) is typically 4 bytes
on a 32-bit architecture, so on most 32-bit architecture setting
xDataLengthBytes to 20 will reduce the free space in the message buffer by 24
bytes (20 bytes of message data and 4 bytes to hold the message length).
(This is an optional parameter that can be set to NULL.)
It is possible that a message buffer will
have a task blocked on it waiting for data. Calling
xMessageBufferSendFromISR() can make data available, and so cause a task that
was waiting for data to leave the Blocked state. If calling
xMessageBufferSendFromISR() causes a task to leave the Blocked state, and the
unblocked task has a priority higher than the currently executing task (the
task that was interrupted), then, internally, xMessageBufferSendFromISR()
will set *pxHigherPriorityTaskWoken to pdTRUE. If
xMessageBufferSendFromISR() sets this value to pdTRUE, then normally a
context switch should be performed before the interrupt is exited. This will
ensure that the interrupt returns directly to the highest priority Ready
state task. *pxHigherPriorityTaskWoken should be set to pdFALSE before it
is passed into the function. See the code example below for an example.
The number of bytes actually written to the message buffer. If the
message buffer didn't have enough free space for the message to be stored
then 0 is returned, otherwise xDataLengthBytes is returned.
size_t xBytesSent;
/* Attempt to send the string to the message buffer. */
xBytesSent = xMessageBufferSendFromISR( xMessageBuffer,
( void * ) pcStringToSend,
strlen( pcStringToSend ),
&xHigherPriorityTaskWoken );
/* The string could not be added to the message buffer because there was
not enough free space in the buffer. */
xMessageBufferSendFromISR() then a task that has a priority above the
task. In most FreeRTOS ports this is done by simply passing
variables value, and perform the context switch if necessary. Check the
