Creates a new message buffer using statically allocated memory. Message buffers execute
a callback upon completion of each send and receive operation. Message buffers created using xMessageBufferCreateStatic() API share
the same send and receive completed callback functions, which are defined using the sbSEND_COMPLETED() and sbRECEIVE_COMPLETED() macros.
Message buffers created using the xMessageBufferCreateStaticWithCallback() API can each have their own unique send and receive completed
callback functions. See xMessageBufferCreate() and xMessageBufferCreateWithCallback() for
corresponding versions that use dynamically allocated memory.
configSUPPORT_STATIC_ALLOCATION must be set to 1 in FreeRTOSConfig.h for
xMessageBufferCreateStatic() to be available. Additionally, configUSE_SB_COMPLETED_CALLBACK must be set to 1 in FreeRTOSConfig.h for
xMessageBufferCreateStaticWithCallback() to be available.
Message buffer functionality is enabled by including the FreeRTOS/source/stream_buffer.c source file in the build (as message buffers
use stream buffers).
xBufferSizeBytes
The size, in bytes, of the buffer pointed to by the pucMessageBufferStorageArea parameter. When a message is written to the
message buffer an additional sizeof( size_t ) bytes are also written to store the message's length. sizeof( size_t ) is
typically 4 bytes on a 32-bit architecture, so on most 32-bit architecture a 10 byte message will take up 14 bytes of message
buffer space. The maximum number of bytes that can be stored in the message buffer is actually (xBufferSizeBytes - 1).
Must point to a uint8_t array that is at least xBufferSizeBytes + 1 big. This is the array to which messages are copied when
they are written to the message buffer.
pxStaticMessageBuffer
Must point to a variable of type StaticMessageBuffer_t, which will be used to hold the message buffer's data structure.
pxSendCompletedCallback
The callback function invoked when a message is written to the message buffer. If the parameter is NULL, the default implementation provided by the sbSEND_COMPLETED macro is used. The send completed callback function must have the prototype defined by StreamBufferCallbackFunction_t, which is:
The callback function invoked when a message is read from a message buffer. If the parameter is NULL, the default implementation provided by the sbRECEIVE_COMPLETED macro is used. The receive completed callback function must have the prototype defined by StreamBufferCallbackFunction_t, which is:
If the message buffer is created successfully, then a handle to the created message buffer is returned. If either
pucMessageBufferStorageArea or pxStaticMessageBuffer are NULL then NULL is returned.
/* Used to dimension the array used to hold the messages. The available
* space will actually be one less than this, so 999. */
/* Defines the memory that will actually hold the messages within the message
* buffer. Should be one more than the value passed in the xBufferSizeBytes
[/code-comment]/* The variable used to hold the message buffer structure. */[/code-comment]
StaticMessageBuffer_t xMessageBufferStruct;
StaticMessageBuffer_t xMessageBufferWithCallbackStruct;
void vSendCallbackFunction( MessageBufferHandle_t xMessageBuffer,
BaseType_t xIsInsideISR,
BaseType_t * const pxHigherPriorityTaskWoken )
{ /* Insert code here which is invoked when a message is written to
* the message buffer.
* This is useful when a message buffer is used to pass messages between
* cores on a multicore processor. In that scenario, this callback
* can be implemented to generate an interrupt in the other CPU core,
* and the interrupt's service routine can then use the
* xMessageBufferSendCompletedFromISR() API function to check, and if
* necessary unblock, a task that was waiting for message. */
void vReceiveCallbackFunction( MessageBufferHandle_t xMessageBuffer,
{ /* Insert code here which is invoked when a message is read from a message
* buffer.
* xMessageBufferReceiveCompletedFromISR() API function to check, and if
* necessary unblock, a task that was waiting to send message. */
