stream_buffer.h
BaseType_t xStreamBufferGetStaticBuffers( StreamBufferHandle_t xStreamBuffer,
uint8_t ** ppucStreamBufferStorageArea,
StaticStreamBuffer_t ** ppxStaticStreamBuffer );
Retrieve pointers to a statically created stream buffer's data structure buffer and storage area buffer. These are the same buffers that are supplied at the time of creation.
xStreamBuffer
The stream buffer whose data structure buffer and storage area buffer will be retrieved.
Used to return a pointer to the stream buffer's storage area buffer.
Used to return a pointer to the stream buffer's data structure buffer.
